Jack for tire changes?
wengr
Hello, my new to me 1996 Escort 20" single axle 3850gvwr trailer did not come with a spare wheel or a jack. How can I determine what is an appropriate style/type of jack, for when I need to change tires, service brakes etc?
dingbat
For working on a trailer I use my 3.5 ton floor jack.
For emergency, on-road work the bottle jack from the truck (Tahoe) works perfectly
MTboatguy
I carry a smallish 1.5 ton hydraulic floor jack in the back of the truck all of the time when I have the boat hooked up as well as a set of blocks and an battery operated impact gun. They don't take up much room and can make the day so much easier in case of a situation that sidelines us.
bigdee
I carry a short length of 4x4 treated lumber with a notch cut in the top to cradle the axle. I wedge it between axle and the ground and drive forward until it raises off the ground.
M2HB
I use a good floor jack at home.
on the road, I carry a quality bottle jack with wood blocks.
US Jack makes some of the best bottle jacks.
superbenk
After having to replace a wheel on the side of the road with the scissor jack from my truck once I decided to buy a 2-ton small rolling shop jack to carry with me. It works great but in hind sight I wish I had gotten a bottle jack instead because it’d be a lot easier to pack & place than the awkward rolling jack.
dennis461
Yes to bottle jack and couple of small pieces of wood or plywood.
get one of these
found here https://www.iboats.com/shop/seasense-easy-lift-jack.html
and other places like this https://www.hannarv.com/P/1456/Springfield1840046QuickChangeRVTrailerJack
bigdee
robert graham
Walmart sells a small red 2 ton floor Jack for about $20....fits in the trunk of car or most anywhere easily....great little Jack for trailers, cars, trucks, etc., etc.....I have 2 of them!
Sprig
Yep like most I carry a hydraulic bottle jack. Also you should carry 2 to 4 tire or wheel blocks.
H20Rat
I've got a seasense easy lift like above, although modified... I drilled a hole through it, and one of the bolts for my spare tire was replaced with a longer one, so I can attach this on back of the spare and leave it there!
Haven't had to use it yet, but $25 for a cheap purchase just to leave it on the trailer.
briangcc
Craftsman trolley jack and 4x4 block of wood - goes between trailer and jack. I don't tow without it.
I also carry a breaker bar and an extendable ratchet. Never know when you might need a bit more leverage.
82rude
Small 2 ton floor jack for me with nice case so its sort of compact and tidy.
