Re: Jack Plate For Lund Boat
Yep, plenty strong to do that- your Pro V transom will handle it fine. Be reasonable about the outboard you put back there and you will be fine...
Again, I wasn't trying to be difficult, I was just concerned that someone was leading you in a wrong direction.... Usually if folks are planning on needing a draft of less than 10 inches, they choose a hull other than a Deep V hull and use a jet versus a prop...
