Re: Jack Plate
A water pressure guage would be a good idea, that you don't raise the engine up, and away from the water pick holes. You may have to replace the drag-link on the remote steering arm, depending on how high the engine is on the transon, or now the jack plate. Those plate's, depending on set-up can make quite a difference in performance. You probably already have one, but a good transom saver for your trailer would be in order.
