sea-hunter
- Joined
- Jan 24, 2002
- 2
I am building a 20 ft tri hull with an 8 ft beam. I ant to use a used motor of about 80 hp to hold down costs. It is a planner hull but will only need to go arount 25 mph. The transom is 25 inches to the lowest point. The jack plates are 6 and 3/4 inches deep by 12 inches high and can be adjusted up and down 3 inches manually. <br />Questions. #1. At what height should I mount the plates. #2. What is the hole pattern for most engines? #3. Will this work okay? Thanks http://www.imagestation.com/album/?id=4292086811&idx=1 ]
