Jb weld
hadaveha
Anyone know where to buy jb weld in a larger container , or anything else that would work on aluminum as well as jb weld
fishrdan
I've bought the boxed set from Lowes or Homedepot, each tube is 5oz. About half the size of a tube of tooth paste.
there are better epoxies for aluminum. look into enecon
However prior to gluing something, I would have it welded.
jbcurt00
Going to have to be more specific Dave.
How big is (are the) hole(s).
Where are the holes?
Hull below the water line, abive, interior panels?
On what boat(s)?
JB Weld and MarineTex are both widely used on aluminum boats.
proshadetree
I so love JB Weld when its used right. Had it in an old Ford radiator for 30 years now. When its used badly man is it a mess.
DeepBlue2010
Lowes (some stores) carry the 10 oz pack (5+5). Amazon carry it as well. Are you using it as putty or you are welding a through hole or a crack?
gm280
Only other epoxies that I ever used that were equivalent or better were expensive epoxies that the government contracted for special usages.
put "JB Weld 10 oz" in google and all kinds show up
Do agree, aluminum welding is better, but then you need a lathe to shave it back down. As others said, what ya working on?
Woodonglass
To answer question specifically...Other kinds of epoxy for filling holes...PC-11 Sold at ALL Ace Hardware stores and Home Depot's 1lb kit about $30 bucks. Shelf life over 3yrs. I know cuz mine is that old and still cures great!!!!
hadaveha
My Meir or is going to use it like a putty his tracker was used in salt water and has some pin holes in the transom.
Woodonglass
Good catchJB!! Yeah for PIN Holes a more viscous Epoxy is needed. the Gluv-It would work fairly well with a cover plate as previously recommended.;)
hadaveha
Ya his boat is the weirdest I have ever seen. He has pinholes. All through the transom some the size of the head of a finishing nail. And some tiny, but he has pinholes nowhere else on the boat, He is in the process of removing all the paint off of the transom and inside the splsshwell. I was thinking unless we are suppressed by it being a lot worse, I was thinking of filling the larger holes and the skimming the entires surface With jb weld or something better. Maybe something with aluminum. In the formula
I bet one of two things is occuring:
the boat had sunk in the salt water and the transom wood is wet with wood.
or the boat owner has something grounded to the transom and not properly bonded back to the battery
if either is the case, you can skin coat it all you want, it wont help
seriously look at Enecon (its what the Navy uses for on-board ship repair while out at sea)
hadaveha
I bout some of that before. It comes I'm like a large tube with a plunger right. If so it great stuff
ondarvr
I haven't used that line of products before, but they look good.
