ebbtide176
- Joined
- Jan 22, 2002
- 2,289
old 77 CJ7 304 2bbl quadratrac autoT400. i have not verified whether its an amc or dana44. the 2 manuals i have give opposite info. one lists this yr having dana, the other lists amc.<br /><br />but it leaks on the front. behind the yoke. i think it just needs a seal. i also think both axle types have same repair instr on this seal. it calls for a special tool to bolt onto the yoke so the nut can be loosened. and it should have @ 210ft/lbs of torque.<br /><br />i was wondering if all of you that have replaced this seal had to use this special tool? or is it ok to just let the weight of the vehicle/tires keep the axle from turning?
