1974 70hp johnson. it was re-jetted for high altitute. jet top #30 bottom #61d. after 7 calls to varios O/B repair shops the consisnsese is 61d High speed jet/oriface is correct for both high and low altitude. FOR HIGH ALT low speed jet/oriface #30. For SEA LEVEL needs to be a #33 or #34 depending on *use. Some books/machanics spoke of a 3rd jet/oriface in the center of bowl-it was not on this carb. just a brass tube from the bowl to the barrel/throat. Hope all the time on the phone/pc/books helps some one.<br />>}}}?>
