Jet Ski in Truck Bed
AZBoatDreamer
So this is my truck and Boat. Second Pict. What if I get a two place Jet Ski and put it in the Back of the Truck and take both to the Lake. My vision First Pict.
How would I be able to Launch the Jet ski from the back of the Truck at the Ramp.
Looking for ways to bring these toys to the lake with one vehicle. Thanks.
RogersJetboat454
Re: Jet Ski in Truck Bed
Bet there's a way... Maybe built some sort of track system that extends out, and is bolted to the bed of the truck.
Just don't end up like this guy;
http://www.youtube.com/watch?v=_Mm2DxCVrGU :D
rowlex
I've considered this as well. I was thinking a stand-up jet ski however. and just loading it onto either a swim platform, or the sundeck on my boat.
I would imagine some sorta ramp to the back of your truck and jackknife the trailer to launch them.
sje0123
Just quick thinking,
Sched40 pipe reinforced inside w/ wood somehow attach that to tailgate and use it as a ramp. truck bed mounted winch to hoist it up. I'm guessing wood would work, but pipe would be less friction. Heavy moving blanket in bet to keep bed and hull from getting all beat up. I don't know about your ramp, but at mine jackknifing would never work. I'd just drop the trailer in the parking lot.
sschefer
Simple - Put the ski on a dolly with four wheels and some carpeted bunks. Rig a 4 point strap with a D ring to the dolly. Get yourself a bumper mounted or bed mounted Davit and then winch it either up and over the side or up and over the tailgate. The idea is not original I saw a guy at the lake this summer with a similar setup on a F250. Worked pretty slick. Once it was on the ramp he just rolled it into the water fired it up. He put the ski on the beach and then launched the boat. I didn't watch him take it out but ... hey he got it in there in the first place so it must have just be a reverse procedure. FYI he had his stuff unloaded before the guy next to him.
There is a pre made automatic easy loader out there but it's around $3000. Called easyloader , easy ramp or something like that. Google it.
Or try this, i would make a longer ramp so the climb is less steep. http://www.youtube.com/watch?v=rjQPqmADFmQ&NR=1
2 waverunners probably won't fit in your P/U bed.
boat1010
You can also make an extension to the back of your trailer that is detachable that you can put another ball on and tow the ski behind the boat.
KD4UPL
I have a friend who built a rack to hold his ski in the back of his truck. It attaches to the hole in the floor where the gooseneck hitch ball goes. He used an ATV winch to pull the ski up on the rack. It pivots down into the water, you let out the winch, unhook the ski, and pivot it back up. It seems to work pretty good. If you're handy with a welder you should be able to make this work.
AZBoatDreamer
Thanks for the Ideas. I only want a two person Jet ski in the back of the truck. Not two skies. ;)
I was thinking of getting a tri fold quad truck bed ramp. The kind that hooks to the tail gate and winch it up. I would lay carpet ply wood on the ramp for a smooth surfice. I have plenty of time to work this out. I wont be getting a ski until next spring anyway.
oldjeep
Don't think I would try that. I've got that type of ramp for loading snowmobiles into my pickup and they are designed to keep from pulling back away from the tailgate, but would pretty easily come loose and pull towards the bed if you were dragging something up it.
