Jhonson 115ETL77S questions
abuelo_draco
Hi, i have a few question about this engine (Jhonson 115ETL77S)
1. Its a 4 stroke right, so does not need mix fuel oil?
2. Where is the shift rod screw, i see a lot of potos but i cant finded, even near of the 2 carburator
Thanks
No, no -----your motor is a 2 stroke and runs on a 50:1 gas oil mix.-------And best get a manual before you turn the key.---Read the manual too.
Find a 5/8" wrench.------Stand on the starboard side of the motor.--------Remove the bolt with a wrench and spread those 2 arms.
????-----Have an assistant move the control box to forward gear.----Observe the linkages that move.-------Now remove the bolt with the 5/8" head and spread those 2 arms that go to the top of the shift rod !.
abuelo_draco
that loud sound is the warning horn, the cause is overheting, i should check the pump w?ter again.
