Joe Reeves WOT timing procedure
nowgrn4
Do you subtract 4 degrees from TDC for the idle stop adjustment just as I did for the WOT setting? Or just set it TDC at idle in a tank?
'03 50HP Johnrude.
Joe Reeves
Re: Joe Reeves WOT timing procedure
The 4? reduction does not apply for the idle cam setting. If the manual calls for say 3?, set it for 3?... whatever your manual calls for.
