I Bought a 9' aluminum Seaking flatbottom boat this weekend with an older Johnson 1.5hp Outboard in like new condition for $250 the only problem is I drained the oil out of the shaft (lower screw) but now I can not find the top screw to see if it is full. I noticed there are four holes in the front of the shaft below the motor and when running the engine no water is coming out. Should there be?. <br /><br />Bill
