Johnson 10 hp SeaHorse lower water pump housing needed
MYXASH
I have a 1962 10hp Johnson Seahorse outboard, model QD-23A I need a lower portion<br />of the water pump housing, can anyone direct me to where I might find one and if possible<br />can anyone tell me whether or not I can use ta complete water pump assembly from other<br />JOHNSON Seahorse models, eg from a 9.5 Seahorse lower unit from 1964-1973? I'm new to this board<br />and would appreciate any info or advice.
Joe Reeves
Re: Johnson 10 hp SeaHorse lower water pump housing needed
My_X..... If you're speaking of the lower bearing and housing assy that sits under the water pump plate, I can't help you with the actual plate but can supply some info on it. The OMC part number is 377186, it has been unavailable since 1984, and you can expect a price of approximately $30.00 when you find one.<br /><br />The water pump question suggests to me that you already have the interchange information. The OMC complete water pump kit has a part number of 382296 and lists for approximately $60.00 (I have two of these left in stock if you're interested).<br /><br />That pump (382296) fits the 1964 to 1973 9.5hp, and the 1958 to 1963 10hp Johnson/Evinrude engines.... (ReevesJ32@aol.com)
