Johnson 10hp 1959
jonesg
I just bought a 1959 J10hp ,
model # QB-20.
http://boston.craigslist.org/sob/boa/920622786.html
Paid $150 .
Guy says it ain't been touched for over 15 years, probably needs coils.
What should I automatically replace or service before bothering to try starting it.
This is a kicker for my 20' CC.
Where can I buy a prop for it.?
lyncraft_mechanic
Re: Johnson 10hp 1959
i would change the lower unit oil, check the spark, compression, change the sparkplugs, inspect the water pump and install a new impeller and rebuild the carb. it wouldn't be a bad idea to spray a little premix into the cylinders before startup either to prevent any damage that could occur after sitting for15 years.
asdasc
Congratulations! Welcome to iBoats. The guys here are great and know everything you need to know to get that running awesome. It is a great motor, a lot of guys here run them.
Read this on awakening an old outboard:
Engine FAQ
While you are there, read up on the rest of the FAQ's, there is a lot of info there!
Good luck and keep us posted on the progress.
jonesg
Engine FAQ
ahh yeh, the FAQ file, shoulda known.
jonesg
sounds like a plan, thanks.
samo_ott
That's a good looking engine. Use 24:1 mix.
TN-25
The props for the 1958-63 Johnson 10 and the 1964-73 9? will interchange. I think the latest versions of the 9? actually used lexan (plastic) props rather than aluminum. I'm thinking 3 blades, 8⅛"diameter, 8" pitch.
Yours is probably one of the last that used the 2-line pressurized tank. Did you get a tank with the motor?
jonesg
I'm going over to pick it up in a few hrs, I'll find out then.
is it a problem?
