great_white_fisherman
- Joined
- May 10, 2020
- 63
The engine runs pretty well, except that between 3/4 and full throttle, it will lurch. Speed will drop for a second then return for a few seconds and repeat. It doesn't do this, or at least far and few between, when below 3/4 throttle. A search revealed it could be the fuel pump is weak or a bad coil causing misfires.
The fuel pump idea sounds like just the ticket based on how it behaves at higher speed. But before I go buying a $600 part, $200 on Amazon or eBay, I was thinking perhaps a bad fuel filter could be to blame. Replaced fuel hose with one off my other boat and it has an inline filter barely a few months old. The one inside the cowling looks original and being an 87 model.....ya. Two fuel filters would be redundant, yes? I can remove the inside one, insert a hose coupling and I'm good to go to see if that's the issue?
Otherwise, if that idea doesn't do it, what could be the problem?
Note - I have the VRO disconnected at the harness and the hose because of reading on another thread that they can destroy a motor if they go bad and that usually the first sign it has gone bad IS destroying the motor. I don't want to take that chance so I'm sticking with 2 stroke gas in the tank....could that be the problem?
