Just got off the lake tonight after testing an SE 300 hydrofoil that I installed on my bassboat. I ran the boat wide open (5800 rpm) for a good while immediately before trailering it. When I was putting the transom straps on and the motor toter, I felt some heat coming off the motor. I pulled the hood and the powerhead was VERY hot. It wasn't bubbling paint, but it was too hot to touch for more than a second or 2 everywhere, not just the heads. I have 23 PSI of water pressure at wide open throttle and a strong tell-tale stream. Water temp in the lake was probably around 80-82 degrees. Is this normal on a V4 crossflow motor? The motor was running great.
