Johnson 112 SPL
I was told that I could make my 112hp a 140 with some new carbs. Was wondering how true that was. Any discussion would be appreciated.
jimmbo
Re: Johnson 112 SPL
just out of curiousity, what year is your 112?
jimmbo
Re: Johnson 112 SPL
does it have the bubble back exhaust cover or the flat version?
jimmbo
Re: Johnson 112 SPL
If it did have the bubble back it would pretty much be the same engine as the old crankshaft rated crossflow 140hp.
emdsapmgr
Re: Johnson 112 SPL
The 112 looks like it was a bubble back. In that case, jimmbo's comments are correct. That engine was made as a propshaft-rated 115. Will perform close to the crank rated 140's of the past. The old 135/140s had better heads and the 140's had the intake filler blocks. Your engine should have the good carbs.
