Re: JOHNSON 115 1979 STATOR REPLACEMENT
Crab... The stator is a dual purpose component, AC charging voltage, and 300v power supply to the powerpack(s). If/when the stator starts to leak/melt down, the voltage to the powerpack(s) drop resulting in the pack not firing properly.<br /><br />Bottom line... When a stator starts to melt down, replace it even if you obtain the proper readings.<br /><br />Note that on the lower amp charging stators such as a 6, 9, 10, whatever, (anything other than the 35amp stators which melt down due to excess heat), the cause of the melt down is usually due to a faulty rectifier.<br /><br />A rectifier can be damaged by reverse polarity such as hooking up a battery or battery charger backwards, even momentarily. This disables the rectifier and eliminates its ability to convert the AC voltage to DC which is needed to charge the battery. The result is that the voltage backs up in the stator and eventually causes it to crack and melt down. You can test the rectifier as follows:<br /><br />(Small Rectifier Test)<br /> <br />Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction. <br /><br />Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other. <br /><br />Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires. <br /><br />Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier.
