He rik
- Joined
- Jul 29, 2020
- 44
Hi.
First, im not english (swede )so apologys for my grammar and vocabulary...and spelling, hope you understand anyway..
Ill got a 115-82, had it for about 25years but since 2005 it been on land, now its time to go skiing and fishing again so started it up and everything seemed to work as it should exept charging, model no J115TLCNB.
With multimeter it showed same battery voltage after replaced restifier (3 wires, 2y, 1r) engine on or off but havent tested full throttel yet just ideling and ca:2000rpm.
Original vas fried, might turned off main switch sometime in the past engine still running or it just died, remember the last trip 2005 whitout electric starter... but rope works fine.
Tach works fine, wot @ ca:5200rpm as before so stator seems to send something correct out, OL on meter between yellow wires from stator to ground, no missfire or any other problems, starts easy and seem in all OK.
Cleaned all ground connections and and connectors, looses 0,1 volt true the igniton checked on purple on engine compared to the red but thats it, same reading on battery and solinoid and red wire on restifier so good connecton there ill think
Anyhow, i got trim/tilt but not the ret/reg-combo, ret on starboard and regulator on portside as in the models whitout t/t, queston is if ill could just disconnect the regulator and hopfully see vultage climbe or do ill risk to fry something?
Can the regulator short out charging if broken or does it just not regulate and let voltage climb?
Or, how do I test the regulator on land?
Link to wire chart, think this is the right one, same setup anyway..
https://maxrules.com/graphics/omc/wi...4_V4_NOTNT.jpg
