Re: Johnson 115 2 stroke 2001 model, Engine shudder between 1200 & 2000 RPM
There is no problem with the 115's. The shuddering is the transition from the low speed jets to the mid range and high speed circuits in the carbs. It is normal on carburetor motors.<br /><br />It can be minimized if the spark and throttle are synchronized, called sync and link in the service manual. Make sure the carb adjustments are not set too rich, and that the engine will turn around 5500 rpm with its prop and a normal load. This is all explained in the factory manual.<br /><br />Another easily overlooked problem is proper thermostat operation. Running too cool can affect the motor at low and mid range speeds.
