Davidandkerrie69
- Joined
- Nov 24, 2002
- 23
I have a December 2000 built 115Hp V4 60 degree Johnson which starts, idles and runs great at full throttle but bogs and dies when coming off idle. To transition from idle to full throttle, I have to push in the choke primer on the key. The engine will then suddenly pick up, throttle up to full speed and run fine.<br /><br />The engine only has 40 hours on it. I've replaced the fuel line, primer bulb, checked the water sep filter. I've taken the boat to a dealer who said the mixture was way off and he adjusted the off-idle mixture screws. The engine ran a little better - I could slowly nudge the throttle up to full speed without dying. Took it back to the dealer who said it needed another 1/4 turn which he did. Engine started to idle rough and smelt of running rich.<br /><br />For a brand new motor, I'm dissapointed to have problems so early its life. I've read in other posts that probs have been found in late model engines as OMC was going bust so quality was poor. Could there be junk in a carb/s causing the prob?<br /><br />Any assistance greatly appreciated. This is very frustrating as the boat is useless for skiing the way it's running.
<br /><br />David
