JPGBU1
- Joined
- Aug 8, 2010
- 30
ok.. long story short. I bought a whaler with a dead '78 115 evinrude 20" shaft. I get a 83 long shaft with about 20 hours on it.(true story) swapped power heads. big boom bang- running like a top and brand new. 17' over 50 mph... 3 hours in? instant- and I mean INSTANT loss of power. check the plugs. cylinder 4 is wet. hmmm.. ok, not a rook to engines, but am to more than 20hp 2 strokes. 454? all day. anyways- carbs had a nice varnish syrup in them from last run in 88... rebuilt them... bypass the vro (ran oil as well in fuel) trolling out and 4 is running like a top again but then loose #1. check compression- yes... 130 all around.(wot) check fuel- fine and dandy. wet plug... water? no. pulled head and the piston looks new! rings are fine- piston moves like it should- cylinder wall looks so smooth I said wow! back together, swap coils... ( have 2 spare heads for parts) still nothing on #4. 3 cylinders are running at 100% still hitting like 35. what the heck? soooo.... I have 4 spare power packs... next will swap it. hoping??? is it a timing issue on #4? fuel- compression- spark, but no fire. I am loosing it. what else could it be? would pay $100 for troubleshooting but I am over powered by 15 hp and no one will touch it. PS first time post... long time reader! you all rule!
