Fj40toycruiser
- Joined
- Jul 30, 2016
- 15
I started this thread to begin to diagnose the problem I am having.
http://forums.iboats.com/forum/engi...40764-2004-johnson-compression-test-procedure
I have an 04' Johnson 115 J115PLSRC. I cannot get the boat to go above 3000 RPM's. If I squeeze the bulb no reaction, if I press the key the RPM's climb. It starts fine, idles fine and drives fine at low speed. I have checked the compression...about 120 on all four cylinders +/- 3PSI. The spark jumps 7/16" and is nice and bright blue. I have tried a portable fuel tank no change. I removed the plastic carb bodies cleaned it up and put back together. I did not however touch the aluminum throttle bodies. I am tackling that now. Is there anything in particular to look for and verify is clean in the aluminum housing? jakedaawg has directed me to clean the bodies and believes I am not getting adequate fuel delivery. It looks like the fuel comes into the throttle bodies via a plastic manifold and out through a metal screen that flows into the plastic carb bodies. There is a gasket on the side which I plan to remove and clean real well but I do not see anything else.
