First things first, what a great forum. I have spent three hours just looking at past messages.<br /><br />Now, back to the help i need. I am not new to boating but new to my 1980 115 Johnson. <br /><br />When i bought the boat i took it to a dealer to fix the faulty trim/tilt, he fixed that but said the engine was getting warm and to fix it, they took the heads off and resurfaced them. Anyway, i was happy i was eventually going to get to try my "new" boat out.<br /><br />Took it to the dam last weekend (JHB South Africa), but it was a pig to start and wouldn't idle or if i got it in gear before it stalled wouldn't get past 2000 RPM.<br /><br />Anyway, got it home and noticed that the quick fit fuel connection onto the motor was leaking fuel when i primed the carbs. Have since replaced the quick connector and new hose clamps on all fuel lines and she runs fine on ear muffs. Could the connector have been the problem? IOf not, what else should i be looking for?<br /><br />Finally, she idles fine and sounds well while running higher revs in gear but has a "splutter/miss" every now and again, followed by some extra smoke through the exhaust, what is causing this? Should i be worried or does she just need a good run?<br /><br />Regards <br /><br />Stephen
