Johnson 120 hard to Start
denis21
I have a 1988 Johnson 120 hp
This spring I was having a hard time to start it. It would burp and puter then die.
I was told to remove the bottem screws on the carbs and pump fresh gae throuth them.
This worked for a while. I found the motoer would cough once and a while at higher speed.
I clean the carbs. No luck it won't start.
Any ideas out there??
denis21
Re: Johnson 120 hard to Start
What I did so far is
1. checked spark on all four Looks good
2. I removed the carbs and cleaned.
3, I connected a portable gas tank with good fresh gas
4 have not check compression yet
Could it be a problem with the VRO could it be getting to much oil?
Denis
