Hi folks,
I've got a new to me Johnson 120. When I rotate the screw counterclockwise to release the pressure and allow the motor to drop down nothing happens, it doesn't relieve the pressure and allow the motor to go down. The trim tilt motor operates and there is some movement, I was trying top off the fluid.
The only thing I can think of after reading a few other posts is that there's a lot of sludge blocking that relief valve screw.
Any ideas you've all got to get that relief valve working would be appreciated.
(Also posted elsewhere) It was suggested to stand on the cavitation plate and try to get it to come down, I'll try that.
Thanks,
Bob
Thanks,
Bob
