Bueller420th
- Joined
- Aug 15, 2009
- 21
I just bought a boat and the motor is a 1993 Johnson J120TLET. I bought it really cheap knowing the boat has been sitting for almost 3 years. I got all the old gas out of the tank and put in new gas. Put the dog ears on it to test to see if she would start and if the Tell-Tale would spit out the water. We were able to get her to sputter for a while before she dies. If we keep the choke on she runs for about 5 seconds after the choke is off. I was told the water pump had never been replaced so I bought a kit which seemed to be missing new grommets but installed the rest of it new. Only won grommet looked to have wear and it was the big circle on the pump cover that screws on to the pump housing at the end.
The problem is that with the old and the new water pump we can never get any water to come out of the tell-tale. When the lower unit was off we could blow air up the water tube and it would come out the tell-tale, testing cranking the shaft and making sure the pump turned. At times we could turn the prop fast and it would seem the pump would slip cause the prop would turn really easy, then it would catch almost like the key they provided in the kit was too small and wasn't catching all the time. We tried putting it in a 70 gallon water tank instead of the ears but no result.
Does any one have any ideas as to why we arent getting any water coming out? Also why the motor won't idle by itself for more than 2-5 seconds, perhaps the carbs need cleaned since it sat so long?
Thanks.
Thanks.
