Dear friends,
I have a 1996 Johnson 130Hp Looper - It was in storage for 3 years - I will not start w/o starting fluid ( ether ) & will only continue running by pulsing the electric primer.
I have checked the float bowls - they are full of "green" gas - IE looks like VRO is working.
Ive checked the fuel pump - it pulses out of the VRO pump during crank - I havent checked the pressure though - but it does pulse gas.
Its got a healthy cranks speed & spark - Ive checked these & it will start on starting fluid OR using the electric primer.
Seems obvious its the carbs - but, how could all four be bad ?
Anything special about doing a Johnson looper carb rebiuild ? - I done many rebuilds in my life .
Couple questions:
1) OMC says not to use chlorinated carb cleaners ?
2) Any tips appreciate - any reason to buy the OMC jet removal tool ?
3) How are Sierra carb kits compared to OEM - any reason to use OEM over after market ?
Thanks !
Couple questions:
Thanks !
