Re: Johnson 140 4 stroke
Musky, I just repowered my Triton 18' center console bay boat this weekend with the Johnson 140 four stroke (18', 92 wide, 1700 lbs). Couldn't be happier. Ran the engine about three hours. Go to
www.suzukimarine.com and look at the boat tests. The have several boat tests showing boat weight, speed, etc. Most are using the the 3 blade 14" x 20". That is what I put on mine and it turns 6250 rpm at wot. That is the upper limit of the operating range with just me in the boat.<br /><br />You won't believe how quiet the engine is at idle. It has lots of power from hole shot to wot.<br /><br />I also ordered a Turning Point aluminum prop as a spare from Iboats. Have not tried it yet.<br /><br />Good Luck.
