While replacing the water pump on a Johnson 140 hp outboard (sorry....year unknown....questimate mid '80's) I noticed that the input shaft where it goes into the gearbox is quite loose. Is this normal? I assume the bearings (and thus the gears) are excessively worn?? If you put a dial indicator right next to the upper gearbox seal, there's .040" - .045" side play. Or does all this not matter because the upper end of the drive shaft is supported and aligned by the engine. The gearbox oil did have water in it (milky) and I assume that the upper seals cannot do their job because of the excessive side play. The drive shaft is also worn where it passes thru the water pump housing. What does it sound like to you guys?
Thanks,
Dave
Thanks,
Dave
