johnson 140 short to long shaft
whalerone
Hi All,
I think i've found a solution to my dead cylinder (wasted piston) in my 1980 Johnson 140 25in shaft.....
I am about to purchase a 1980 Johnson 140 20in shaft motor for replacement. Can anyone confirm that it is possible to change out the mid-sections and make this work???
mikesea
Re: johnson 140 short to long shaft
If you want to replace the blown powerhead ,with the one you bought,no problem as long as its a 140 and not an 85 or 90,they have different exhust set ups,
whalerone
Hey thanks...but does this mean I still have to take off the powerhead or can I simply lower the mid-section and lower unit down and then swap??
Thanks...
