wineyarders
- Joined
- Jun 22, 2011
- 46
Hi, I've been down the long low compression troubleshooting road on my '85 johnson 15 which ended with 2 new GLM cast pistons standard size. After finally getting them inserted into the cylinders they seem too tight. I can move them but there is definitely friction and it is not a smooth pull and the rings are snug without any play. I lubed the pistons and cylinder with oil before putting them in. I plan on calling GLM in the morning but thought the helpful folks on this forum might have some insight. IU degalzed the cylinders with some borrowed spring hones but went very light as I didn't want to throw anything out of whack. Another point is there doesn't be a single point that is causing a hang up. Is it common for these pistons wo be out of speck? I have a cheap pair of calipers that seems to say the old and new clylinders have very similar diameter, and the pistons fit, they just seem tight. Any thoughts? Many thanks,
Ryan
Ryan
