Johnson 150 hp 2000 overheating alarm help!
mcarthur121
Here is the problem.. Running at full speed the HOT light and buzzer come on and I immediatly loose RPM's. When I back off the throtle the buzzer and light go out within about a minute or two. S.L.O.W apparantly kicks in because I cannot run over 2500-3000 rpm without problems. When I kill the power and wait a few seconds the motor again will run at full speed until the problem repeats. I changed the water pump, housing, ect. last season and seem to have great flow (through the telltale) I have changed out the T-stats today, test ran but had the same problems. I felt around the motor but really didn't feel any super hot spots. Does anyone know how to check the Temp sensors? Is it possible that water is not flowing through the t-stats at all even though they are new and the pump is reasonably new and there is good flow through the telltale?
I also ran out of gas not to long before this problem began could this have anything to do with the high temp alarm.
