I have a 1985 Johnson 150.<br />The engine runs and has the VRO disconnected. I have rebuilt the carbs and re-installed them. With the engine running on the hose, I installed my inductive timing light on each plug wire and have only two cylinders firing. Looking from the stern toward the bow, the top two left cylinders are the only ones firing. <br />This is why I believe the engine would not get on plane and seemed to bog down when trying since it was only running on two cylinders.<br />Can I remove the flywheel and sand the underside to make sure I am getting juice to the coils?<br />How do I test the coils?<br />How do I test the Alternator?<br />The engine is model #J150TLCOS
