I have a 2002 Johnson (Bombardier) 150 2-stroke. It has always been very hard starting. Toward the end of this past season, I had several times when the engine simply would not start, and I drained the battery right down without the engine firing even once. I use the QuickStart feature, turning the key part way until the chirp sounds, and the red check lights all go on and off, then press in for choke, then turn the rest of the way. Plenty of juice to the starter motor, but it just won't fire at all. Sometimes the chirp sounds again and the red lights come on again when I turn the key the rest of the way to start the motor (doesn't seem like this is supposed to happen). No leaks in fuel system, and the plugs are all brand new and properly gapped. Local dealer can find nothing wrong. Any advice???? Many thanks. -Warhawk
