Johnson 150 VRO - STALLING
EGalvTex
I'm sure one of y'all has a good idea as to what my problem is: The engine revs and runs fine in nuetral (sputters some at low idle) but runs poorly and stalls out while in gear. After stalling, however, it starts back up fine. I think it could be carburetion trouble???
JB
Re: Johnson 150 VRO - STALLING
Howdy, EGT.<br />Could be carb problem, could be something else.<br /><br />What year engine?<br /><br />With multiple carbs, it is more likely that you are down 2 or 3 cylinders. Sounding good with no load doesn't tell you much. It can do that on 2 cylinders.<br /><br />Pull plug wires one at a time. If there is no change, that is a dead cylinder. If rpm drops, that cylinder is making power.<br /><br />If you have 2 cylinders dead, opposite each other it is the carb feeding those two. If you have three dead on the same side, you have lost one of your ignition systems, probably a powerpak.<br /><br />If all cylinders are making power at idle, look into your fuel pump and fueling system.<br /><br />Good luck<br /><br />Red sky at night. . .<br />JB :)
EGalvTex
Thanks JB, I'll try that out. By the way, its an '89. :p
Prickly Pete
I had a similar problem on my 2000 150 Johnson. Would not run in gear after shutting it off for a couple minutes or more. To fix the problem, the shop had to adjust the carbs leaner than normal, but its ran great every since. :)
Paddling
Hello EGT, I have an '86 150. Had a very similar problem one time when I accidently knocked the linkage from the timer base to the throttle lever loose. Engine started and reved without any back pressure but with exhaust in water it would stall. When I popped the linkage back in place all was right once again.
