I would like to convert a 1978 Johnson 15HP longshaft motor, Model 15RL78B,Ser.# E5010904, from my sailboat to a standard shaft length. I have purchased a standard length shifter & driveshaft. I can not remove the copper water tube to replace with standard length and am considering cutting it with a hacksaw blade. <br />Any thoughts on doing this before I make the cut?? I am assuming I can restore the water tube to original length by using a compression fitting and re-connecting the cut-off piece.<br /><br />Thanks.
