Johnson 15hp Speed
Defiant
Hey all
Can any of you guys give me some speed's your Jon boat's run with a 15HP on them .I took mine to the river yesterday and was getting 23MPH out of it that's on a 1436 Jon the prop that is on the motor is a 9 1/2x12 1/2 (stock prop) I forgot my tach so couldn't get any RPM'S .The boat weigh's 170lbs by it's self but I have added a floor and storage compartment guessing the weight to be about 400 lbs with motor and battery/gas .
Thank's
jbjennings
Re: Johnson 15hp Speed
Same speed for me (23mph) on GPS with a 12'36" johnboat. If you want to see more search out "Poll: how quick do your outboards push" by WBeaton. we've all piled on a bunch of speeds there--a pretty neat thread....
JBJ
Defiant
I thought It might be a little faster but maybe not what RPM's are you guy's getting at that speed .I was by myself when I ran it yesterday .The prop on the motor need's replaced it is a little nicked up might have to drop to a 91/4x 11 if the RPM's are to low.
wbeaton
That's about top speed for that motor on a utility/jon boat.
Defiant
It's a JR 1436 Crestliner I had every intention on checking my RPM's yesterday thought of everything but the Tach .I did take the 5HP Suzuki with me also got it up to 13 MPH
BF
speed sounds about right, but 12 1/2" pitch sounds too high. I don't think that would be stock. What year do you have? I bet your rpms are low. I think a 9 or 10" pitch would probably be about right. I think I have a 9" on my 15 hp...
Defiant
It's a 1995 15HP the 9 1/2 x 12 1/2 is the stock prop for that year (Listed in Manual) I called around and found a 9 1/4 x 11 in case the RPM'S are to low gotta wait till I can get a tach on it though. He also has the Stock prop.
Defiant
http://shop.evinrude.com/ shows 2 props for that motor. 10x9 high thrust and 9x11 as stock props.
Johnson 1995 15HP J15EEOD
PROPELLER, 9.5 x 10, 9.9 models. Refer to OMC SysteMatched Parts & Accessories Catalog for Propeller Chart
PROPELLER, 10 x 7, 9.9 Sail. Refer to OMC SysteMatched Parts & Accessories Catalog for Propeller Chart.
PROPELLER, 9.5 x 12.5, 15 models. Refer to OMC SysteMatched Parts & Accessories Catalog for Propeller Chart.
http://shop2.evinrude.com/ext/index.aspx?s1=f470b3f529bd90264724b6be70584a05
I have a 12ft v-hull jon boat with a 60hp evinrude e-tec it runs 70+ mph its out of control likes to fly
