vortec_cruiser
- Joined
- Dec 20, 2007
- 17
I recently purchased a 1986 Cajun Espirit 18.5' bass boat with a 1985 Johnson 175 engine. Both boat and engine appear to have been taken very good care of, and had been always garaged. The problem I'm experiencing is the engine bogging down (fuel starvation?) at higher boat speeds. The engine starts and idles just fine, and even at low to moderate boat speed it does fine. But as soon as I try to give it more throttle, it bogs down. It reminds me of a car with a partially plugged fuel filter, running fine a lower speeds, but not passing enough fuel at higher speeds.
I cleaned the fuel filter, which had some dirt in it, but not enough to cause this problem. Prior to my purchasing the boat it had been started infrequently in the previous year or two, and I'm pretty sure no fuel stabilizer had been used. I had filled the tank with about twelve gallons of stabilized fuel prior to running the engine. As stated above, it starts and runs at lower RPMs just fine. I'm thinking the main jets are plugged. There is also the possibility of a partially blocked fuel tank (built-in) outlet. The previous owner said he had rebuilt the carbs about six months ago, and has a receipt from a dealer who adjusted the linkages.
Any help or suggestions would be appreciated.
