1985mariner20
- Joined
- Nov 23, 2012
- 24
Took out my new, old boat today. 1988 Johnson 175 on the back. Cruised around for an hour or so before I started having an issue. When ever i slow down to an idle then try to throttle up, the boat dies. I was able to get a higher engine rpm by using the cold start lever a little, then I was able to get cruising again. At the ramp trying to load up, same issue, whenever I tried to give it throttle to get up on the trailer, kept dying. Thinking ive gone a lean issue. Not sure though. only happens after boat has warmed up to operating temp. Any help would be much appreciated!
