First, I want to give a big thank you to all of the people here who have posted advice and answers to questions. I'm not a mechanic by any stretch of the imagination but I've been working on getting my Grandfather's 1954 Johnson 10HP running again. When I pulled it out of the shed it had been sitting in for 10-15 years it wouldn't start. After working on it, I took it out on the lake for the first time today! Today's trip was to adjust the carb needles as described in this forum. After the adjustments she ran great. This would not have been possible without the information I found on this forum. So thank you to iboats.com for hosting this forum and thank you to all the people who provide answers to questions.
Work done so far:
1) Cleaned and re-gapped points. No spark until this was done.
2) Replaced plugs
3) Checked lower unit lube. It's brown but not milky. Noticed that there are no washers on the lube ports. Guess I need to find a source for them.
4) Rebuilt carburetor.
5) Cleaned inside pressure tank and rebuilt pressure thank pump
6) Rebuilt the fuel connector (actually I found a guy on eBay who does it for a fee. Well worth the price. I'd probably have made a mess trying to pick the old dried rings out with a dental pick)
7) Adjusted carburetor needles as described elsewhere on this forum.
I do have a couple of questions remaining that I haven't been able to find the answers to yet:
1) The water pump seems to be good. At fast idle (start) there's a good spray of warm water out the water discharge port. At wide open throttle the spray is stronger. When the boat's not running, the bottom of the water discharge port is just above the water. I noticed that if I tilt the motor up a little, moving the discharge port a few inches above the water, the RPMs come up. Is this normal? Is it a cause for concern that the discharge port is so close to the water?
2) After running at wide open throttle for a few (5-10?) minutes, the heads sizzle when water is splashed on them. Is this normal? Can anyone tell me an appropriate temperature for the heads on this model? I know my model does not have a thermostat so I was surprised that the heads got so hot. Lake temperature was 78 degrees, so there should have been plenty of cooling available. The heads cooled down within a minute or two after returning the throttle to idle. I know for a fact that this motor has never been run in salt water, so salt build up should not be a problem.
3) Twice, I heard a loud bang a few seconds after opening the throttle wide. It sounded like the lower unit had hit something, but I was in 60 feet of water. The first bang was before I adjusted the high speed needle. The second was after adjusting the high speed needle but before adjusting the low speed needle. Is this normal? Should I be worried? Maybe it was a backfire? I did not hear any more bangs after adjusting both needles.
4) I've read elsewhere that the needles need to be "perfect." There is a small imperfection at the tip of my motor's low speed needle (see picture). Looks like someone seated it a bit too hard. Is this a cause for concern? It idles pretty well (better than my nearly new Nissan 5HP 4-stroke!) but does occasionally miss. Could the imperfect needle be the cause?
Work yet to do:
1) Find washers for the lower unit lube covers and replace lower unit lube
2) Replace the cowl bumper studs and bumpers. The studs for the old ones broke off. I tried running without the bumpers but the cowl makes an awful racket rattling at anything above start throttle.
3) Replace water pump impeller.
4) Figure out what else needs to be done based on answers to the questions above.
I'm pretty happy with this motor and want to make sure I'm caring for it properly. Thanks in advance for help anyone can give me in finding answers to the questions above.
Work done so far:
2) Replaced plugs
Work yet to do:
