Johnson 1954 cd-11
Cleatus61
I have a Johnson 1954 cd-11. The Motor mount on the motor is broken. Where can I get a free parts breakdown online so I can figure out what parts I am going to need. Are these parts still availible or do I need to find somthing used.
Scaaty
Re: Johnson 1954 cd-11
Best bet is keeping an eye on ebay...
F_R
You can get all the free advice you need right here. Tell us exactly what you need, or a picture of it and we can give you the part number.
It sort of irritated me that you specified "free". There are givers and there are takers.
Cleatus61
Sorry, I didn't mean free parts. What I need is a part breakdown to see what I need
Cleatus61
Here is picture of another motor I found online. The arrow indicates where it is broken
F_R
The spring retainer is part number 303372, the steering pilot shaft that the spring retainer is fastened to is part number 303500. You probably will need find a junker to get those parts.
BruceAML
303372 is a good part number that can be ordered from an OMC dealer. I thought you wanted a motor mount. That part number may not be what you need.
F_R
The arrow points to the spring retainer, the number I gave. That motor has springs for mounts, not rubber like the newer ones.
Cleatus61
The "springs" then went to the bottom of the lake. I think what happend then was the screw for the strap came off and then everything came apart. Does the strap hold everything together?
F_R
Yes, the strap holds it together.
Springs are 303461 (takes two)
Screw for the strap is 303397
Both are available new from a dealer, or used wherever you find them
