maybe you guys can help me I'm told I can change out the lower unit from a 56 10hp Johnson to my 18hp, this is the deal I'm pretty sure the lower unit is toast when I take it out even if I change the lower unit oil right before the trip by the time I hit the ramp there is milky white oil leaking out of it most likely just a seal but when I'm driving the boat slow it runs fine and when I try to open it up the motor revs very high as if it's coming out of gear could this be fixed I'm getting a good deal on two 10 1956 models one is a good runner and the other runs too but is mostly a parts motor will the lower units be compatible and help please
