Just bought a 1960 Glasstron with a 1962 Johnson 55hp outboard. I had the oil changed and water pump kit replaced. Boat was working fine for the first couple outings. Went out fishing in the kelps yesterday. Chopped up some kelp with the propeller and I think I over worked the motor. On the way back when I pushed down on the throttle the engine started to make noises and wouldn't accelerate past a low speed. Im also not sure if the water pump is working properly. Does this type of motor have a streaming line of water thats supposed to **** out? When we got to the dock I took off the cap and touched the top of the motor. It was very hot! Before I call a mechanic and "BOAT" BRING ON ANOTHER THOUSAND
I thought i might pic away at the forums guru's.
