Here the probleme i have i dont know if someone can help me. Inside the lower unit i have they hydrolic pump inside they have some piston this piston when is work great push the cluch dog to the neutral and reverse position and when is in foward the piston return by the spring inside the pump but now my probleme is that they dont return inside the spring is ok i dont know what to inspect????<br /><br />thank you!!!
