johnson 1972 20 hp long shaft to short shaft conversion
jwilkey84
I have a long shaft 20hp johnson, 1972. It has apparently been made from a short shaft to a long shaft at some point in its life. I just want some opinions on this. I think all I should need to convert it back to the short shaft is a short drive shaft, water tube, and shift linkage. Is this correct? I would have to take out the 5" extension on the midsection, install the already mentioned parts, and wallah! I just want to know if I am thinking this through right. changing the drive shaft doesn't scare me. changing the shift rod doesnt scare me. But I have never had a water tube out. How are they connected to the bottom side of the powerhead? Is this hard to change out? I know what most of you are thinking, this isn't cost effective. Well I know a guy with a whole pile of old parts motors, most of which I can buy for $25 a piece. More than likely he has a short shaft motor from that era that will work. Talk to me guys, tell me if I have thought this through or if there is something I am overlooking.
F_R
Re: johnson 1972 20 hp long shaft to short shaft conversion
You have your head together. Without looking, the water tube probably sticks up into a rubber grommet in the midsection housing.
jwilkey84
if that is the case, I should be able to just pull out the long water tube and insert the short one, correct? I was just wanting to make sure ther was no mechanical connection up there under the powerhead that was going to be a pain in the neck to get to.
F_R
OK, I just looked to make sure I'm not leading you astray. Yes it just pokes up into a rubber grommet. Same kind of grommet as in the water pump housing.
There is another part that you didn't mention. There is a round tube around the drive shaft, between the water pump and exhaust housing. There are long and short versions of it, so you need one of those too.
griffbuff2002
can you tell me if there is a spacer for a 150 evinrude to change a sort shaft to a long thanks.
Don Hansen
F_R
I noticed that tube when I changed the water pump on my 35. Made of plastic. Do you know what the purpose of that tube is?
Don H
