hi, i need help with my Johnson 55 hp 1979 , i change piston and ring, new kit of gasket, change the 2 coil and have good compression 150 psi each cylinder, but i cant adjust low idle speed at 1500 rpm engine stop, engine at wot speed is very good, someone can help me to find the problem ??
the 2 carb. don't have low speed adjust and the scree for max low speed is on max so i cant turn more.
Thanks for your help!
