Johnson 1980 4 hp Pee hole
Boa tarde , Comprei um velho Johnson 4 hp 1980, Model n° J4BRCSS, fabricado em Bruges Bélgica. O motor funciona perfeitamente, a bomba d'água parece OK, mais eu não consegue localizar a saída da água na traseira do motor. Alguém poderia me ajudar . Grato
iggyw1
Ensign
Take some thick nylon line (like from a weed whip) and try cleaning the weep hole with that, or a straightened out paper clip. The hole may be plugged up. If that does not clear it, try to run the motor with the pee hose taken off of it and see if you get a stream of water coming out of the motor before it gets into the hose. If so, clean or replace the hose.
I do not believe there is a pee hose / hole.------Cooling water mists out of a series of holes on the back of the exhaust housing.
Vic.S
I think you will find that the question is, " the engine works perfectly, the water pump seems OK, but I cannot locate the water outlet at the rear of the engine. Could someone help me?"
I believe Racerone is correct. There is no telltale / pee hole on this model.
