boomer2001
- Joined
- Feb 20, 2011
- 10
ok tried to trim motor the other day, click click, so looked at relays, wires lil corroded so replaced them all with new wires, connectors, etc. cleaned box up, all back together, checked every wire for continewed everything a ok, hit the trim switch nothin, check power to motor, have power to both green and blue when trim switch is used in either up or down. up puts power to b/g wire down puts power to g/b wires. new relays and still the same problem. hooked motor to battery working as it should there. Need nelp it truely baffling me. thanks Boomer
