johnson 1989 150gt
river rat1
ok here my problim my sparks plugs are wet is it becase when i tilt my engin up yesterday it itle fine and ran it for a cpl min went to the dock to pic my buddy up tilt the engin up it die and whold not start took the boat outwater and pulled the plugs were very wet took it home waite about 3hr and took out back hook it up to the garden hose started right up tonight went to the river and did not startpluse i clend my carbs today if any one can help i thank u a lot
emdsapmgr
Re: johnson 1989 150gt
Possible you have a spark issue. If you have any weak ignition components, they tend to fail once the engine heats up to normal operating temperatures. When it won't run, check for spark on all 6 plugwires.
river rat1
i just check spark the top one each side no spark and all 6 spark plug was very wet and oiley do u think that my problim is thanks
emdsapmgr
Solve your no spark problem first. You may find the oily spark plug issue goes away.
