Johnson 1998 ELECM won't shut off with key or kill switch
midsized johnson
[FONT=&quot]The other day, pulled up to a spot to fish and the motor wouldn't shut off when I turned the key off. Tried pulling the kill switch and that didn't kill it either. I let it idle for a bit and it eventually died, did that twice. It died after I gunned it getting it on the trailer, so no issue at the ramp! Anyway, last night I flushed the motor, turned the key off and it absolutely wasn't going to die (until the gas ran out), so I pushed the key in to flood it and killed it that way. I realize the key switch kills the motor by grounding the connection, I'm guessing the black/yellow(?) wire has a break in it somewhere, not letting it ground out and kill the engine.
A little background:
I have the new remote control box for that year model, mostly, if not all, plastic housing. On the way to fish that morning, it was a little rough, and took a some water on the console and I felt like I got a shock when I touched the console and remote control handle at the same time, this happened twice during the day. Last night when it wouldn't die, I pulled the main plug at the remote which, as I expected, had no effect on the engine running.[/FONT]
Daviet
I think you are on the right path with the black/yellow wire. You are going to have to check the wire to find out where it is broken or disconnected.
midsized johnson
Problem solved! Break in the ground wire somewhere in the harness, so spliced in a wire on either end of the harness connectors and ran it along side the wiring harness.
